2000 Honda Odyssey broken wire on ciggarette lighter
184,000 MILES • 6 CYL • FWD • AUTOMATIC
MRUTHERFORD7
trying to fix broken ciggarette lighter. the black wire has broken away from black plug. I tried pushing the clip inside blk plug out to re attach wire but failed. what is the best way to fix the problem.[img:4b357f3f2e]http://www.2carpros.com/forum/automotive_pictures/559672_100_3861_1.jpg[/img:4b357f3f2e]
Aug 9, 2010 at 3:30 AM
KHLOW2008
  • 41,812 POSTS
Hi mrutherford7,
Thank you for the donation.
Remove the broken terminal from the connector. If the other end has a white or other colored piece in the center, use a sharp object to pry it out. You would see a locking tab inside. Pry the locking tab away and push the old terminal out.
Get a new terminal to clamp onto the broken wire and push it back into the connector. Reinstall the locking piece and you are good to go.
Aug 9, 2010 at 4:46 AM
