Hi Dave,
Jack up front wheel and put safety stands after loosening lug nuts.
Remove wheel.
Remove brake calipers and mount.
Remove rotor.
Remove CV joint central nut.
Knock damaged lug stud out.
Install new lug nut and tap in as much as possible.
Use lug nut with spacer to pull the lug nut into final position.
Reverse removal procedure to complete.
Note : When tightening the CV joint central nut, tighten and release a few times to allow the hub to be fully seated before final tightening.
Sep 7, 2010 at 2:04 AM
