I have a 99 Honda Odyssey that acts like it's dropping into Neutral while I'm driving. Every gear acts like Neutral... When I stop and turn it off and back on it goes into gear and drives fine for a little bit, then acts like its back in Neutral (The gear shift level is still in drive...I even try shifting into other gears)
The ignition switch went out and I had it replaced because it was on the recall list.
I also had AAmco rebuild the Transmission ($3200.00) and it seemed to work for about a year...As soon as the AAmco warranty ran out it is doing it again. I have only driven it 10,000 miles since AAmco rebuilt the Transmission.
I think it's a little strange that the rebuilt Transmission is acting the same was as the old transmission...Any Ideas?
Dave
Dave
Sep 3, 2010 at 10:30 AM
