1999 Honda Odyssey Special tools to remove rotors
KG4TYR
Brakes problem
1999 Honda Odyssey 6 cyl Front Wheel Drive Automatic
Are there any special tools required to remove the rotors on this vehicle? I previously owned a 1997 Accord and there was a tool required to remove the rotors. I don't want to get this half way torn apart and find out I need something special to finish the job.
Nov 5, 2009 at 11:01 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Once you get everything else apart and are read to remove the rotor there are 2 6mm disc retaining screws.
You will need 2 - 8 x 1.25 x 12mm bolts. Put them in existing holes and alternate tightening until disc comes off.
Nov 5, 2009 at 11:18 AM
KG4TYR
So the 6mm screws are removed and the 8mm screws are then threaded into the holes forcing the disc off?
Nov 5, 2009 at 11:56 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Well, yes that is how it is supposed to work. However, in most cases you will need a hammer also. Snug the 2 bolts down and turn another 1/4 turn then take hammer and hit around center, then tighten bolts down some more, continue till disc comes off.
Nov 6, 2009 at 3:59 AM
KG4TYR
Thank you, doesn't sound like it will be too bad (if you have a big enough hammer)
Nov 6, 2009 at 12:07 PM
