1999 Honda Odyssey Rear brake cylinders
1999 HONDA ODYSSEY
10,600 MILES • 6 CYL • FWD • AUTOMATIC
DWOLLEAT
A chain-store brake repair facility mechanic told me that the rubber covers at each end of the rear brake cylinders were to keep dust out, and not to prevent leaking. He then preceded to pull back the rubber covers, at which point brake fluid poured out. If the rubber covers were not leak-proof, why was the fluid not evident before he pulled the cover back? Also, was there supposed to be no fluid loss when the rubber covers were pulled back? Were the cylinders definitely leaking?
Thanks much!
Mar 28, 2008 at 5:23 PM
MERLIN2021
  • 17,250 POSTS
The chain store guy is right! If you peel the boot back to inspect for leaks, a very small amount of wetness is OK, but if it drips, or pours fluid out, they are most definatly bad! Replace them. There is another seal inside the cylinder behind the steel piston, ask him to show you when he removes it.
Mar 29, 2008 at 12:12 AM
