1999 Honda Odyssey radiator /water pump /timing belt
90,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEFAUCHER
The radiator leaks. Mechanic suggests to replace it. Also he suggests to replace the water pump & timing belt.
My money is short. I know I can replace the radiator my self, but I'm not so sure about the water pump & timing belt. I had done this job once before on a 77 Ford LTD I had many years ago, but thats the ony time I did that.
I'm debating if this is worth me trying to do myself to save a few hundred bucks on labor, or if I should just try to work out something with the garage to pay for them to do it.
Dec 22, 2009 at 3:40 PM
  • 31,937 POSTS
HI there,
The timing belt is not due to be replaced until 105,000 Miles, do the radiator now and save up for the timing belt job, you do not have to replace the water pump when the belt is done, some mechanics will suggest this as it is only a few bolts after the timing belt is removed, if there is no noise or signs of leaking you can choose to leave it.
mark (mhpautos)
Dec 22, 2009 at 4:02 PM
MIKEFAUCHER
[quote:213aa61512="mhpautos"]HI there,
The timing belt is not due ti be replaced until 105,000 Miles, do the radiator now and save up for the timing belt job, you do not have to replace the water pump when the belt is done, some mechanics will suggest this as it is only a few bolts after the timing belt is removed, if there is no noise or signs of leaking you can choose to leave it.
mark (mhpautos)[/quote:213aa61512]
Thanks for the very quick response Mark. I'll follow your advise. This mechanic is generally OK, but he has done work for me before that I think could have had more focus on customer satisfaction vs lining his wallet.
I hope you have a safe/happy/healthy holiday season.
Mike
Dec 22, 2009 at 4:19 PM
  • 31,937 POSTS
Ok that a good move, if you intend to do the belt and pump job and you need assistance feel free to come here, that is what we are here for,
Have a safe and happy Xmas and new year,
Thank you for using 2carpros,
Feedback is always welcome.
Mark (mhpautos)
Dec 22, 2009 at 4:32 PM
