1999 Honda Odyssey Passenger side view mirror
1999 HONDA ODYSSEY
111,000 MILES • 6 CYL • 2WD • AUTOMATIC
CSARVIND
I bought the replacement housing with mirror and not the entire mirror assembly. The glass broke on the old one - need to remove the plasic piece that the glass is stuck to - need instructions for removing the old housing,
Apr 16, 2010 at 2:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Wear gloves and eye protection when removing the mirror glass.
1.Carefully and evenly, pull up on the lower edge of the mirror holder slowly, until it unsnaps from the actuator. If necessary, disconnect the heated mirror leads.
To install:
2.Carefully align the clips and hooks, and using even pressure, snap the mirror holder downward onto the actuator base.
3.Check the mirror operation.
Apr 16, 2010 at 3:04 PM
