1999 Honda Odyssey half of the interior (driver side) light
1999 HONDA ODYSSEY
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
OKWONG
no sure what to look for, the dome light will open when door on right side were open; but not the driver side. the dashboad light is out as well. low and high beam work normally. can't drive in dark, as can't see the speed.
Aug 29, 2009 at 11:11 PM
KHLOW2008
  • 41,814 POSTS
Hi okwong,
For the dome light operations, check the driver door switch. wiggle it and if light comes on, the switch contact is bad.
For the dash lights, if the taillights and front side lamps are not working, check for blown taillight fuse or relay.
Aug 31, 2009 at 3:20 AM
