Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Odyssey
Engine
Symptoms
Revs Up
1999 Honda Odyssey Engine revving
1999 HONDA ODYSSEY
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
BISHOP LIAM
MEMBER
1 POST
My engine has started revving and will not go all the way down when idling. It does this at stop points and when the engine is in neutral.
Mar 1, 2009 at 10:27 AM
KHLOW2008
Experienced Mechanic
Hi Bishop Liam,
The idling speed is out of specs and possible causes are :
1. Faulty Idle Air Control ( IAC) valve. Is the Check Engine Light showing when driving?
2. Vacumn leakages. Check for dislodged vacumn hoses, faulty PCV and leaking brake power booster hoses.
3. Insufficient coolant in radiator.
4. Idle Adjust screw out of adjustment.
Mar 3, 2009 at 3:02 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
