1999 Honda Odyssey DRL
180,000 MILES • 6 CYL • FWD • AUTOMATIC
IGOR
I have been having a problem with the left side daytime running light. It will just come on slightly. It seems like its missing a boost to run the bulb fort that mode. Full driving lights are fine and the left side works fine. Please help. Thank you.
Oct 21, 2008 at 12:57 PM
KHLOW2008
  • 41,812 POSTS
Hi igor,
At DRL control unit ground the Red/Orange wire at terminal and if headlight works, the control unit is bad.
If it does not work, check for bad connection of the Orange/White. Use jumper to connect to Red/Orange wire and if it works, the passenger under dash fuse relaybox connection for thr DRL is bad.
Nov 29, 2008 at 4:34 AM
