1999 Honda Odyssey daytime running lights
1999 HONDA ODYSSEY
140,000 MILES • 6 CYL • FWD • AUTOMATIC
RONALD310
The DRLs work intermittently. When not working the passenger side drl does not come on, and when the lights are turned on full, to stop the buzzing sound, the high beam on the passenger side does not work either. But some days everything works ok. I replaced both headlight bulbs, no change. I tested the electronics on computer at the garage and no problem code came up.
this is a canadian version car.
Feb 22, 2009 at 4:41 PM
HONDATECH74
  • 34 POSTS
[quote:4164d08bb0="ronald310"]Electrical problem
1999 Honda Odyssey 6 cyl Front Wheel Drive Automatic 140000 miles
this is a canadian version car.[/quote:4164d08bb0]check for corrosion on the connector of the headlight bulbs.
Feb 27, 2009 at 12:33 PM
