1999 Honda Odyssey
Is there a trick to removing the rear brake light housing without damaging the car or the housing itself once I have removed the two screws? The directions in the Owner's Manual instruct the reader to remove two screws and simply pull the housing towrd the rear of the car. But the housing seems to get stuck when I try to slide it out. Is there a screw or something there that should be addressed? Or do I ignore that and just pull harder? I sure don't want to damage anything.
Nov 15, 2008 at 7:23 AM
