1999 Honda Odyssey
1999 HONDA ODYSSEY
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
99STEPHEN
i have a problem with my odyessey, it just started skipping,i got a tech told me that all my cyclinders are misfiring except #2 what could be the problem. i have change oxygen sensor, egr valve, spark plug
Mar 8, 2010 at 2:46 PM
Engine running rough or misfiring can be cause by the following:
Inspect and test all the following listed below.
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
Mar 8, 2010 at 2:50 PM
