1997 Honda Odyssey Vibration Accelerating Uphill
1997 HONDA ODYSSEY
BILL NAPIER
Noises problem
1997 Honda Odyssey 4 cyl Front Wheel Drive Automatic
Recently, whenever I engage the accelerator to go from the bottom of a small incline/hill it creates an almost buzzing vibration from under the hood. The noise seems to be from the front area of the hood.
I have manually tried to shake/move all visible parts under the hood, but except for the radiator, which moves slightly, everything is as tight as when new.
May 18, 2008 at 3:49 AM
KHLOW2008
  • 41,814 POSTS
Check the front or rear engine mountings for wear.
Check also the air cleaner assy. Sometimes a loose bolt will cause the vibration noise.
May 26, 2008 at 4:01 AM
