Can the igniter in a Honda odyssey be replaced without replacing the whole distributor?
Sep 23, 2008 at 3:09 PM
KHLOW2008
✓Experienced Mechanic
Hi Locolobo1,
Yes, but are you sure it is the ignitor and not the ignition coil? Test the coil promary and secondary resistance first. Also check if power is getting to the distributor Black/Yellow wire with ignition switch ON
Oct 10, 2008 at 11:12 AM
