HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Odyssey
Electrical
Ignition Switch
Key
SPONSORED LINKS
1997 Honda Odyssey Ignition problems
FLWILLIE01
MEMBER
1997 HONDA ODYSSEY
6 CYL
FWD
AUTOMATIC
230,000 MILES
When ignition key is turned car does not crank.
Thursday, August 21st, 2008 AT 10:25 AM
KHLOW2008
MECHANIC
Hi FLWillie01,
Did you check the battery voltage, terminals connection etc?
Can jump start work?
SPONSORED LINKS
Saturday, August 23rd, 2008 AT 11:17 AM
FLWILLIE01
MEMBER
Thanks, found loose wires and starter went bad.
Saturday, August 23rd, 2008 AT 12:58 PM
Please
login
or
register
to post a reply.
Related Ignition Switch Key Content
1995 Honda Odyssey Won't Stay On
Transmission Problem 1995 Honda Odyssey 6 Cyl Two Wheel Drive Automatic Car Won't Stay On When You Let Go Of The Key
Asked by
adammmmm
1995
HONDA ODYSSEY
Key Will Not Turn, Is It The Cylinder Lock Or Ignition...
It Started A Few Days Ago, I Jiggle The Key And Turn The Steering Wheel Until It Turned. Now The Key Will Not Turn At All. I Want To Know...
Asked by
bcmullen95
4 IMAGES
2005
HONDA ODYSSEY
How To Replace Ignition Switch
Hi There, How Does One Change An Ignition Switch On This Vehicle?
Asked by
molsoncanadian
1 IMAGE
1999
HONDA ODYSSEY
1995 Honda Odyssey Ignition Is Locked - Key Will Not...
Interior Problem 1995 Honda Odyssey 4 Cyl Front Wheel Drive Automatic 195000 Miles The Ignition Will Not Turn With Car In Park....
Asked by
Kodak
1 ANSWER
1995
HONDA ODYSSEY
No Electrical Power, Will Not Start
Yesterday I Noticed That The Van Had Absolutely No Power. No Lights And Would Not Crank At All When I Tried Starting. I Replaced The...
Asked by
chasebsmith
7 IMAGES
2006
HONDA ODYSSEY
VIEW MORE
SPONSORED LINKS
Battery Replacement Toyota
Battery Replacement
How to Replace Battery
Online car repair manuals
