1997 Honda Odyssey Cylinder 2 Misfire code and failled smog
1997 HONDA ODYSSEY
190,000 MILES • 4 CYL • 2WD • AUTOMATIC
STACILACEE
I have a 1997 Honda Odyssey, took for a smog test and check engine lite was on. The tech said it would not pass with lite on. Checked the code and was a cylinder 2 misfire. Smog test failed said emissions were very high.
Any ideas what it could be. Wondering if it is something I can try to do or how much money it might take to fix it.
Appreciate any info. Thanks!
May 28, 2010 at 8:11 AM
Hi stacilcee, Welcome to 2carpros and TY for the donation
A specific cylinder misfire should lead you to check the sparkplug, compression and injector for that cylinder-
High emission on HC/CO could be the catalytic converter or air injection pump
May 28, 2010 at 8:39 AM
