1996 Honda Odyssey van won't idle when air running
1996 HONDA ODYSSEY
LEGGAZOID
Air Conditioning problem
1996 Honda Odyssey Automatic
My daughter's van won't idle after turning air conditioning on. It also backfires. She has had a couple of mechanics look at it, all with different solutions. Idle's fine otherwise.
May 6, 2008 at 4:25 AM
KHLOW2008
  • 41,814 POSTS
If the idle drops very low when AC is on, the EACV is most probably clogged. Use a carburettor cleaner to clear the clogging.
The misfiring part might be due to spark plugs or cable defect.
May 26, 2008 at 4:19 AM
