1996 Honda Odyssey SPARK PLUG WIRE POP OUT WHILE DRIVING,
ALEXACUNA
Engine Mechanical problem
1996 Honda Odyssey 6 cyl Two Wheel Drive Automatic
while driving the engine started to shake. Came home and notice that one of the spark plug wire had pop off the engine I tried to put it back one and the car won't start. I notice that there is oil on the wire where you connect to the spark plug.
Oct 25, 2009 at 2:12 PM
  • 75,988 POSTS
Hi alexacuna and TY for the donation
The valve cover gasket on that side could be leaking down to the sparkplug hole and shorting out that cylinder or cylinders-inspect
Oct 25, 2009 at 4:33 PM
ALEXACUNA
can you explain why did it the spark plug wire just pop out of the spark plug. how do i fix the problem
Oct 25, 2009 at 5:29 PM
  • 75,988 POSTS
Either its loose connection on the wire to plug or its leaking compression thru the plug due to not being torque properly or the plug well is crossthreaded out bcuz improper installation of the spark plug.
Try torquing it down to 13ft lbs
Oct 25, 2009 at 7:10 PM
