1995 Honda Odyssey speedometer
170,000 MILES • 4 CYL • FWD • AUTOMATIC
CLARKLC34
The speedometer and odometer stopped functioning recently for no apparent reason. Everything else eectrical associated with the dashboard guages appears to be operating normally. The transmission shifts normally and there are no other obvious problems. The check engine light is not on
Thanks for your help
Sep 29, 2008 at 2:07 AM
KHLOW2008
  • 41,812 POSTS
Hi clarklc34,
Thank you for the donation.
When speedometers don't work, the usual fault is the speed sesnor.
Sep 29, 2008 at 5:20 AM
