1995 Honda Odyssey ignition is locked - key will not turn t
1995 HONDA ODYSSEY
195,000 MILES • 4 CYL • FWD • AUTOMATIC
KODAK
Interior problem
1995 Honda Odyssey 4 cyl Front Wheel Drive Automatic 195000 miles
The ignition will not turn with car in park. Nothing seems to free it to trun and start the car.
Aug 2, 2008 at 7:09 AM
KHLOW2008
  • 41,814 POSTS
Hi Kodak,
If turning the steering wheel to release the tension on the locking pin does not help, the key tumblers are stuck and you might need some lubricants in the key cylinder with some twisting and turning to get it working again.
Get a locksmith to rebuild the tumblers or replace the key cylinders once you can get it going.
May 23, 2017 at 4:41 AM
