1995 Honda Odyssey CV Joint
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
RUTHGOLF18
If the above vehicle hit a curb and damaged the tire, is the CV joint damages or is this wear and tear.
Feb 26, 2009 at 4:33 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:9175cfa068="ruthgolf18"]Drive Train Axles Bearings problem
1995 Honda Odyssey 4 cyl Two Wheel Drive Automatic 100,00 miles
If the above vehicle hit a curb and damaged the tire, is the CV joint damages or is this wear and tear.[/quote:9175cfa068]
It would depend on how hard you hit the curb did it damage the rim?
It could be from wear and tear but the hit may have expidited the failure of the CV Axle. It could have also damaged the Wheel Bearing.
Feb 26, 2009 at 4:41 AM
