1995 Honda Odyssey
1995 HONDA ODYSSEY
CASPER_8789
Transmission problem
1995 Honda Odyssey 4 cyl Two Wheel Drive Automatic
Is it ok to use Castrol Import Multi-Vehicle ATF in my 1995 Honda Odyssey? I just bought used and it shifts hard. I checked the transmission fluid and it was low, and brown with a burnt smell so i added the above fluid it didnt seem to fix the problem.
May 9, 2009 at 2:40 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:cbdcee68b9="casper_8789"]Transmission problem
Is it ok to use Castrol Import Multi-Vehicle ATF in my 1995 Honda Odyssey? I just bought used and it shifts hard. I checked the transmission fluid and it was low, and brown with a burnt smell so i added the above fluid it didnt seem to fix the problem.[/quote:cbdcee68b9]
You need to do a filter and fluid change on it. What you call shifting hard is probably the tranny slipping then catching the gear which will make it feel like a hard shift.
Being Brown and Smelling Burnt means the fluid has lost it's ability to perform.
May 9, 2009 at 2:47 PM
