2001 Honda Insight No Heat or Defrost
2001 HONDA INSIGHT
140,000 MILES • 4 CYL • FWD • MANUAL
ELEYARMS
  • 5 POSTS
Car runs great but neither the heater nor the defroster output any heat. Temperature gage shows that the engine is heating up. The radiator was recently replaced and refilled. There is water/coolant mixture in the radiator. (AC system was recently replaced and but has yet to be recharged, if this is significant.) External air temperature sensor is in place. What is/are the likely problem(s)? And how can we pinpoint the problem? How do I enter the Sensor Input Display Mode? The instructions on page 21-44 of the manual do not do anything. Thanks.
Jan 3, 2009 at 3:42 AM
IMPALASS
  • 3,112 POSTS
Hello
Please check your heater hoses going into the firewall..are both the same temperature or is one hot and one not
Jan 3, 2009 at 2:55 PM
ELEYARMS
  • 5 POSTS
The Insight is equipped with a rubber-capped standpipe that supplies coolant to a portion of the system between the engine and firewall. If a system has been completely emptied, that portion of the system must be replenished with a funnel and small tubing. Once the coolant in this portion of the system was replenished the heater began working.
Jan 4, 2009 at 7:10 AM
IMPALASS
  • 3,112 POSTS
Hello
Great ..so you are good to go
Jan 4, 2009 at 9:18 AM
IMPALASS
  • 3,112 POSTS
Hello –
Hey, one more quick thing, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
02-081
12/17/2002
Recall - Emissions/ECM Replacement
01-098
10/29/2001
Recall - PCM Software Update
06-027
02/16/2008
Campaign - Warranty Extension for IMA Battery
07-049
02/05/2008
Campaign - A/T, CVT Start Clutch Warranty Extension
07-050
02/05/2008
Campaign - A/T, CVT Drive Belt Warranty Extension
06-026
02/05/2008
Campaign - Premature IMA Battery Module Failures
06-057
02/05/2008
Campaign - Warranty Extension for IMA Battery Module
07-038
11/07/2007
Campaign - ECM Update for MIL ON/DTC P0420
01-102
11/27/2001
Campaign - Integrated Motor Assist Controller Update
NHTSA04V086000
02/01/2004
Recall 04V086000: Headlamp Switch/Connector Defect
02-049
08/02/2002
Recall - Passenger Air Bag Replacement
NHTSA02V196000
07/01/2002
Recall 02V196000: Passenger Air Bag Replacement
Jan 4, 2009 at 9:20 AM
HONDATECH74
  • 34 POSTS
[quote:d2817f5392="eleyarms"]Heater problem
2001 Honda Insight 4 cyl Front Wheel Drive Manual 140000 miles
Car runs great but neither the heater nor the defroster output any heat. Temperature gage shows that the engine is heating up. The radiator was recently replaced and refilled. There is water/coolant mixture in the radiator. (AC system was recently replaced and but has yet to be recharged, if this is significant.) External air temperature sensor is in place. What is/are the likely problem(s)? And how can we pinpoint the problem? How do I enter the Sensor Input Display Mode? The instructions on page 21-44 of the manual do not do anything. Thanks.[/quote:d2817f5392]I would have to say the most probable problem is the water valve and or cable. seeing that the ac system has been replaced the cable could have been left off of the valve.
this is located at the rear of the engine bay and should have a heater hose connected on either side.
Feb 27, 2009 at 12:27 PM
