2009 Honda Fit parasitic Draw
2009 HONDA FIT
7,200 MILES • 4 CYL • 2WD • MANUAL
GARY FELIX
My car has an intermittent parasitic draw which drains the battery after I drive It a few hours and park it.
Honda cannot trace or find the problem.
They have replaced the battery.
Is this problem common, rare, or reported in my Honda or other makes? Do other vehicles share this problem?
Feb 26, 2010 at 7:14 AM
KHLOW2008
  • 41,814 POSTS
Hi Gary Felix,
One of the most comon intermittent parasitic draw would ba a sticking fan relay.
Do you have instances of the cooling fans working when the engine is off?
Mar 3, 2010 at 5:41 AM
GARY FELIX
I do not have a stickey cooling fan on this fit.
we will check for this sticky relay switch.
Thanks Gary Felix
Mar 3, 2010 at 8:19 AM
KHLOW2008
  • 41,814 POSTS
Sorry if I did not make myself clear.
Sticking means the relays operates normally and sometimes do not cut off causing the component it is supplying power to continue working.
It can be any relay such as cooling fans, head lights, blower etc.
Mar 4, 2010 at 12:28 AM
