2009 Honda Fit Battery removal
6,000 MILES • 4 CYL • FWD • MANUAL
POLECAT73
I plan to store my 2009 Honda Fit Sport in an unheated barn for the winter, to keep it out of winter road salt. Can I safely remove the battery to keep it warm and charged in my home? There is no electric power to the barn. I am concerned about messing up the car's computers by leaving them without power for about 5-6 months.
The reason for this question is a similar problem that happened with my '98 VW New Beetle Diesel. Loss of battery power resulted in a tow to the dealer to re-program the car's engine control computer.
Could this happen on my '09 Fit?
Thank You.
Nov 17, 2009 at 5:08 AM
KHLOW2008
  • 41,812 POSTS
Hi polecat73,
Thank you for the donation.
Yes, you can safely remove the battery to store the vehicle.
In the nineties some manufacturers started the idea that when removing the battery, the PCM would lose its programmed state and you would need to reprogram it to start the vehicle. I have no idea of the actual reason for the system, maybe to ensure vehicle owners gets back to the dealers or a theft prevention.
That was a failure and since then manufacturers has reverted to the normal procedure whereby no reprogramming is required but most engine control units are inteligient units and some relearning would be required whereby the vehicle has to be driven over some distance before it gets back to its optimum state.
So don't be surprised if the vehicle does not perform according to what it was before removal of the battery. Some driving later should get it back.
Nov 18, 2009 at 11:16 PM
MMPRINCE4000
  • 8,548 POSTS
Anytime you store a vehicle longer than 30 days, add a fuel stabilizer to fuel.
Sep 17, 2010 at 12:38 AM
