2003 Honda Element Front Noise on Turns
FARMERKURT
2003 Honda Element EX, automatic trans. with ~80,000 mi. I am experiencing significant noise in the front end when making tight radius turns. It sounds like the AWD system is binding somehow or is engaged all the time. Am I low on fluids or is there a mechanical problem?
Sep 13, 2007 at 2:09 AM
BRUCE HUNT
  • 3,754 POSTS
Well I would first crawl under the vehicle and look at the CV boots to see if any of them are torn, ripped or cracked. If they or one are chances are that the axle will need to be replaced. Does it do it in each direction?
Sep 13, 2007 at 6:05 AM
Suggested Repair
Inspect the CV axle boots underneath for tears, rips, or cracks. If a boot is damaged, the axle likely needs replacement. Also note whether the noise occurs when turning in both directions.
Conversation Summary
The owner of a 2003 Honda Element EX automatic with about 80,000 miles reports significant front-end noise during tight turns that sounds like the AWD system is binding or always engaged, and asks whether fluid is low or there is a mechanical problem. The expert recommends inspecting the CV boots for damage and says a torn boot likely means the axle should be replaced, while also asking whether the noise occurs in each direction.
