2006 Honda Element Enging Heating up
40,113 MILES • 4 CYL • 2WD • AUTOMATIC
LCSPUMBA
My engine started to heat up, the a/c does not work properly(stops cooling at a stop, cools up as I speed). I looked at the fuse box and the one that indicates cooling fan #4 20AMP looks ok. What might be the problem? Could it be the cooling fan relay? If it is which one is it
thanks
Sep 3, 2009 at 11:45 AM
KHLOW2008
  • 41,812 POSTS
Hi lcspumba,
Did you test if the cooling fan motors are good?
Sep 4, 2009 at 5:51 AM
