2005 Honda Element left front brake noise
FAITHX2
Brakes problem
2005 Honda Element 4 cyl Front Wheel Drive Automatic
Hi Guys,
I recently did a complete brake job on my sons car.
He says there is a clicking noise when he is coming to a stop. I have had it torn down twice now.
I did not replace front brake as they are like new. I did have all 4 rotors turned. I noticed the shim in left front is loose. Please help this is precious family members.
the noise is in left front brakes.
Thanks Dennis
Jun 5, 2010 at 11:47 AM
  • 75,988 POSTS
Try replacing the loose shim could be it that's making the noise.
Jun 5, 2010 at 11:54 AM
FAITHX2
hi Rasmataz
Is there any other reason there could be a clicking noise when applying the brakes. This is the only tmime you can hear it is when you are almost to a complete stop.
These are almost new pads. I did have all 4 rotors turned.
I have done over a 150 brake jobs in my life time with no probles. Help
Thanks Dennis
Jun 7, 2010 at 2:55 PM
  • 75,988 POSTS
Check the wheel bearings and the CV Joint on that side
Jun 7, 2010 at 7:10 PM
FAITHX2
Hi My friend,
I have checked everything with no evail. Also what could cause the new pads on the rear to apply when going in reverse. The left rear applys then the right.
What devise pulls the pads away from the rotors after releasing the brakes
note... you can actually hear the rear pads appling when stopping in reverse.help
thanks Dennis
Jun 8, 2010 at 6:47 AM
  • 75,988 POSTS
What devise pulls the pads away from the rotors after releasing the brakes , its self adjusting-check the caliper piston if its retracting and the brake hose
Jun 8, 2010 at 8:19 AM
