2004 Honda Element What is a tune up?
88,000 MILES • 4 CYL • AWD • AUTOMATIC
JKHANNINEN
When someone tells me my car needs a tune up, what is normally included in that?
Jun 18, 2009 at 7:16 AM
HONDA TECH 1818
  • 536 POSTS
You are near 90k service, 90k service include oil change, trans. service, coolant, air filter, ac filter, brake inspection, brake fluid change, differential fluid change, tire rotation and inspection of suspension components. Did you have your valve clearance check at 60K, if not recommend to check the valve clearance. Your spark plugs are due at 110k.
Nov 15, 2009 at 2:58 PM
