2003 Honda Element Cabin Air Filter/Engine Air Filter
2003 HONDA ELEMENT
60,000 MILES • 4 CYL • 4WD • AUTOMATIC
RLD00442
How to I access and how do I change the cabin air filter on this vehicle? Should I do this or is this a dealership issue?
How do I access and how do I change the engine air filter on this vehicle? Should I do this or is this a dealership issue?
Are both of these parts available after market or are they only Honda parts?
Jan 10, 2008 at 10:37 PM
BARBERIAN
  • 11 POSTS
You can find them both online and at the dealer..
To change the Air filter
Looking at your engine on the right side you will see a round air box with a big tube coming out of it. There are a few screws you can remove and the air filter is right under it. Refer to you Honda manual.
There are pics and instructions how to change it.
The cabin air filter is under your glove box.
Open your glove box. Empty it. There are two black latches on each side. Take those out and the glove box will fold down. Behind it you will see the fan system for your A/C. the filter is in that unit. There is a rectangular shaped cover that you undo and pull out. The filter is attached to it.
Replace and reinstall.
The Honda manual pics and instructions for this also.
Good luck
Oct 31, 2008 at 4:55 AM
