2003 Honda Element
2003 HONDA ELEMENT
80,000 MILES • 4 CYL • AWD • MANUAL
PEEZLEPOP
The washer fluid pump is not functioning. It blows the fuse when I try to use it. I'm assuming that it's in the reservoir. Does the headlight need to come out in order to take the reservoir out? Do I need to remove that plastic housing/bumper to get the headlight out? Do I need a tool to deal with that?
Thanks,
Jim Paisley
Aug 8, 2008 at 11:32 AM
KHLOW2008
  • 41,814 POSTS
Hi Jim,
You don't need to go that far.
Just remove the right fender inner liner and you can get access to the tank and motor.
Aug 16, 2008 at 2:32 AM
PEEZLEPOP
Thanks very much!
Aug 19, 2008 at 2:13 PM
