1997 Honda Del Sol Clutch Problem
1997 HONDA DEL SOL
79,546 MILES • 6 CYL • 2WD • MANUAL
DENNYBL3
Just replace the clutch disc, pressure plate, throw out bearing and the bearing inside the flywheel. I also replace the throw out fork as it had signs of wear. Upon completion of the job there is a rattle/odd noise when in neutral or while driving. Clutch operates well. Please advise. Thank you.
Jun 14, 2010 at 1:40 PM
F4I_GUY
  • 3,302 POSTS
Something is loose. It may be a loose bolt, or even a loose pressure plate/flywheel. If it sounds like it's coming from underneath the bell-housing, the transmission is going to have to come off.
Sep 19, 2010 at 6:24 AM
