1995 Honda Del Sol how to remove transmission
1995 HONDA DEL SOL
STEVE552
Transmission problem
1995 Honda Del Sol 4 cyl Two Wheel Drive Automatic
whats the easiest & fastest way to remove to remove the drive axles?
Dec 13, 2008 at 9:16 AM
TED-E-DEE
  • 109 POSTS
Remove axle nuts. remove lower ball joint cotter-pins & nuts & remove lower ball joint from knuckle, pull knuckle out & off shaft. Use med. size pry bar & pop inner joint out of trans. - CAUTION -Hold onto INNER JOINT when pulling axle out of trans., if you pull on the shaft in the center , the shaft & bearing can come out of the caseing. It can be difficult to get bearing back in. I've had to disband the boot more than once to get them back in. { Did'nt learn the 1st time.} You can pull them out to the wishbone & let hang there or you can emove wishbone bolt & take them out.You can then have axle in hand. Up - Dated 4/26/09 { SUN. }
Apr 10, 2009 at 1:56 PM
