1995 Honda Del Sol replacing heater hoses
1995 HONDA DEL SOL
173,358 MILES • 4 CYL • FWD • AUTOMATIC
SRYE89
i have a heater hose that is cracked and has a slow but steady leak. the hose is leaking where it connects to the engine under the distributor. need information on what is involved to replace the hose.
Apr 6, 2010 at 10:41 AM
F4I_GUY
  • 3,302 POSTS
Very simple. Follow the hose until you reach the heater core inlet at the fire wall. Remove the clamp and carefully pull off the hose. Do the following for the otherside.
Note: you will want to drain the coolant via the rad draincock first.
Apr 24, 2010 at 5:32 AM
