1995 Honda Del Sol knock sensor
82,000 MILES • 4 CYL • 2WD • MANUAL
MUSTANG02
I have a 1995 Honda Del sol DOHC VTEC that I need to change the knock sensor on.Do I attempt this from the top or bottom of the engine? what is the best way to replace the knock sensor?
Aug 22, 2009 at 4:20 AM
KHLOW2008
  • 41,812 POSTS
Hi mustang02,
Thank you for the donation.
The knock sensor is located below the intake manifold and you would not be able to access it from the top. Only way is to get under the car and work from the oil filter area.
Removing the oil filter would allow you easier access.
Aug 22, 2009 at 4:54 AM
