1995 Honda Del Sol Engine idles up and down and stalls when
17,556 MILES • 4 CYL • 2WD • MANUAL
LITOMEKANIKO
This vehicle was replaced with another motor, as the original motor was stolen. However, when first started, the engine runs like hunting until the engine warms up. However, anytime gas pedal is pushed for more rpm, the engine stalls. I cleaned the IACV, cleaned the throttle body, have a good fuel pressure and spark, but still doing this stalling problem. What would cause this kind of a problem? All ideas are most welcome.
Oct 13, 2010 at 6:43 PM
F4I_GUY
  • 3,302 POSTS
You cleaned the IACV, which is good, but you must also clean the FITV which is located below the throttle body.
Oct 23, 2010 at 10:04 AM
