1995 Honda Del Sol
1995 HONDA DEL SOL
BOBSYKES66
Engine Performance problem
1995 Honda Del Sol 4 cyl Front Wheel Drive Manual
When giving car gas it bogs down during lower RPMs. With higher RPMs it accelerates just fine. Just purchased car so don't know if it needs timing adjustment, tune up, ?
May 23, 2010 at 9:47 AM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 23, 2010 at 11:16 AM
