1995 Honda Del Sol
1995 HONDA DEL SOL
10,300 MILES • 4 CYL • FWD • AUTOMATIC
TAMIEKESSLER
Need help....I have a honda del sol that is acting funny. A week ago the car ws idleing high and then low on its own as if someone was hitting the gas---I had this "fixed" they said it was a T-Hose and radiator was low of anti freez.....Today it started again with idel problems...When I stop at a red light or am sitting still in Park or Drive -- The car shakes and the RPMS drop to 0 and then go up a bit but feels like its going to shut off, I hit the gas and it still does it ?????
Jan 22, 2010 at 12:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is your check engine light on?
this can be caused by several things. vacuum leak(s), faulty throttle position sensor, fault idle control valve etc... best to check for any trouble codes stored first. if none found then start with basics such as searching for vacuum leaks
Jan 22, 2010 at 1:06 PM
