1994 Honda Del Sol distributor
1994 HONDA DEL SOL
10,000 MILES • 4 CYL • FWD • AUTOMATIC
PJB6575
My 1994 Del Sol turns over but the spark does not appear when I checked it so I know i either need a coil or a part in the distributor. do i need to replace both? i already replaced the fuel pump but it still doesn't start. it sounds like it's about ready to start but it doesn' turn over. Just trying to find out what part i need to buy so i can get it fixed. Thank you.
Sep 23, 2008 at 6:17 AM
KHLOW2008
  • 41,814 POSTS
Hi pjb6575,
Check for power supply to distributor Black/Yellow wire with ignition switch on. If power is available, test the igniton coil primary and secondary resistance.
If within specs, you need to replace the ICM.
Sep 26, 2008 at 4:13 AM
