Once my car reaches 3,000 RPM's it bogs out like a governor kicking in; never going past 3,000. The check engine code show's Crank Shaft Positioning Sensor. Two things done: installed a MSD ignition box, and replaced the distributor. The MSD box needed replaced since the old one shorted out and I replaced the distributor with an OEM, after reading a forum that this problem lies within. I've searched for the position of this sensor with little luck. I'd like to know where to start. Thank you
Sep 25, 2010 at 5:02 AM
