1993 Honda Del Sol CARS TEMPERATURE GAUGE IS FLACTUATING
1993 HONDA DEL SOL
152,000 MILES • 4 CYL • FWD • AUTOMATIC
HONDADELSOL1993MIL
CARS TEMPERATURE GAUGE IS FLACTUATING? i REPLACED THE FOLLOWING NEW WATERPUMP, THERMOSTAT, HOSE, AND RADIATOR. THE THING IS THAT THE CAR IS BOILING IN THE RESERVOIR AND SPURTING COOLANT OUT OF THE RESERVOIR.
Oct 2, 2009 at 3:13 AM
KHLOW2008
  • 41,814 POSTS
Hi hondadelsol1993mil,
Did you bleed the system after replacement of the parts?
Did you recheck the coolant level?
Are the cooling fans working?
Oct 2, 2009 at 4:49 AM
HONDADELSOL1993MIL
Yes, the mechanic did. new coolant everything.
Oct 2, 2009 at 6:09 AM
KHLOW2008
  • 41,814 POSTS
A fluctuating temp gauge is usually an indication of insufficient coolant in system. Could be due to air trapped in system.
When engine is cold, remove the radiator cap and check the coolant level.
Check the recovery tank coolant level as well. Top up if necessary.
Oct 3, 2009 at 12:32 AM
