1993 Honda Del Sol Car turns over but wont start.
1993 HONDA DEL SOL
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
SIN0CIDE
Occasional I have an issue with starting the car. First I try to start it and it turns over and seems to start but then dies right away or shortly after. Then I try to turn if over again and it turns over but does not start. If I turn it off and leave it for 10-15 minutes it will start up and run perfectly. This happens randomly and Its been hot/cold/raining/dry and it doesn't seem to matter. I did have someone try to steal my car and they messed up the ignition switch but I got it to go back to the off position and it worked fine every since then till just recently. It seems to be an issue were something shuts off the fuel after it stalls and it resets shortly after. Any ideas of where to start would be good.
Aug 16, 2010 at 10:09 AM
Inspect and test the ignition switch and main relay
Aug 16, 2010 at 11:17 AM
