car will not drive forward until warmed up for five minutes?
132,000 MILES • 1.4L • 2WD • AUTOMATIC
LIBBY300
  • 21 POSTS
Hello, my CVT transmission has recently developed a fault, when parked overnight the car won't drive until warmed up for 5 minutes it will reverse but not drive, then the car is good for the whole day and transmission is normal. It's just when it's stood overnight for a long time. I've checked fluid level seems fine and there are no warning lights on dashboard.
Nov 9, 2022 at 7:11 PM
  • 55,694 POSTS
Yep, these CVT transmissions are known to have problems, but let's run the codes to see what comes up. You could have a transmission speed sensor or pressure control solenoid going out. Have you serviced the unit lately?
Here is a guide to help you run the codes:
Please go over this guide and report back.
Nov 11, 2022 at 1:09 AM
