1990 Honda CRX Tachometer Jumping
ZEPOL
1990 honda CRX. 143,000. 5spd. My tachometer is all over the place. There is no noticeable change in engine speed. There are no strange sounds. I have observed this under many conditions and there are not any that correlate. Just have a very hyperactive tachometer. Thanks in advance.
Jun 14, 2007 at 9:02 AM
BRUCE HUNT
  • 3,754 POSTS
If the speedometer is not jumping around, I think the tach is bailing on you. Had a 1990 and had to replace it doing the same thing.
Jun 15, 2007 at 1:54 AM
ZEPOL
thx for your response. i had heard that it could be caused by fault in the ignition system. i replaced the plugs, wires, distributor cap, and ignition rotor. this work for about 100 miles. might continue in this direction a bit more...if you have any thoughts...thx again
Jun 19, 2007 at 9:53 AM
ITZ_2_EAZY
hi the tach jumping is do to the coil underneath the dizzy cap. only takes 5 min to change will fix your problem.
Aug 7, 2007 at 10:58 AM
Suggested Repair
If the speedometer is steady, replace the failing tachometer. Also check the ignition coil under the distributor cap, since a coil fault was reported to cause the same jumping tach.
Conversation Summary
A 1990 Honda CRX with 143,000 miles has a tachometer that jumps around with no matching change in engine speed or unusual noises. An expert said the tachometer itself is likely failing and should be replaced if the speedometer is steady. The owner replaced the plugs, wires, distributor cap, and rotor, which helped for about 100 miles. Another reply said the coil under the distributor cap is the cause and is a quick replacement.
