90 crx vibration when i drive
1990 HONDA CRX
SK8ERAL13
i have a 5 speed crx si. there is a vibration when ever i start goin and it does this thru every gear and every mph...it just started happening all of the sudden and i thought it was my cv axels so i got those replaced and it still does it. so i dont kno what it could be
Sep 8, 2007 at 4:20 AM
BRUCE HUNT
  • 3,754 POSTS
CV axles wouldn't do that. I hope they were bad for other reasons. Is this vibration felt through the steering wheel, the entire car or what? The thought that comes to mind is motor mounts. I would be checking the motor mounts. Check them one at a time. Using a partner, I would run the engine and watch as the car is put in to gear forward and backward while accelerating with the brake on. The engine will try to move and you should be watching for excessive movement at the mounts.
Sep 13, 2007 at 6:10 AM
