1992 Honda CRX honda delsol 1992
1992 HONDA CRX
105,000 MILES • 4 CYL • 2WD • MANUAL
NATHAN300
  • 30 POSTS
hi there,
i have a honda delsol 1992 (15 vtek) and i have transmission problems .the 2nd gear slips , and on bumpy roads,it tends to pop back to neutral , unless i push the gear knob. and i have a nasty noise on the second and third gear. i dicided to buy a new clutch . which do you think is the best clutch to buy for this model ?
thanks in advance and keep it up!!!!!!! your help is much apriciated
thanks nathan ( awm.vella@gmail.com )
Feb 4, 2010 at 3:35 AM
KHLOW2008
  • 41,814 POSTS
Hi Nathan,
The 2nd speed jumping to neutral is not a fault with the clutch whereas the slipping is. Replacing the clutch is not going to rectify the jumping out of gear. You would need to check the gear linkages and engine mounts and if good, the trans would need a rebuild or replacement.
OEM clutches are the one I would recommend as replacement.
Feb 5, 2010 at 3:27 AM
NATHAN300
  • 30 POSTS
thanks for your reply.
ill keep that in mind . will it be expensive to get the job done ?
nathan
Feb 5, 2010 at 10:20 PM
KHLOW2008
  • 41,814 POSTS
The second speed synchronizer gear itself would not cost much but if the hub and gear set, then it would cost $371.33 with labor time of 8.6 hours.
Feb 6, 2010 at 12:52 AM
NATHAN300
  • 30 POSTS
ok then, thanks for all your help .
keep up the good work and keep it up!!!!!
Feb 6, 2010 at 5:28 AM
NATHAN300
  • 30 POSTS
hi there,
sometimes, it's hard to put the first gear from idle. same with the reverse.
this happens randomly but not often.
thanks for your help!
keep it up
nathan
Mar 29, 2010 at 11:04 PM
KHLOW2008
  • 41,814 POSTS
This is an indication of the clutch disc freeing itself late and is due to lack of lubricity on the clutch shaft splines. You would need to remove the transmission to do it.
Mar 30, 2010 at 2:41 AM
NATHAN300
  • 30 POSTS
ic , but i am doing a lot of damage by leaving it like that for now ?
Mar 30, 2010 at 4:35 AM
KHLOW2008
  • 41,814 POSTS
If you keep forcing and crashing the gears, then yes, it can cause a lot of damage.
When trying to engage 1st and reverse, depress the clutch and wait 2 seconds before shifting. It should reduce the crashing.
Mar 30, 2010 at 4:46 AM
NATHAN300
  • 30 POSTS
ok then thanks for your help !
keep it up !
nathan
Mar 30, 2010 at 4:49 AM
NATHAN300
  • 30 POSTS
hi there ,
just a quick question .
is it ok to top up my car with engine oil frequently?
i top it every 2 months ( give or take )
my car burns oil and my mechanich told me its from the oil seals and until i fix the problem i am topping up whenever i see it a bit low.
thanks very much and keep up the good work guys !
keep it up
May 18, 2010 at 6:43 AM
KHLOW2008
  • 41,814 POSTS
Constant topping up is not a problem, not topping up will be if it is leaking or consuming oil.
May 19, 2010 at 4:11 AM
NATHAN300
  • 30 POSTS
thanks very much for your help .
May 19, 2010 at 4:12 AM
KHLOW2008
  • 41,814 POSTS
You are welcome.
Have a nice day.
May 19, 2010 at 5:28 AM
