1991 Honda CRX Where is the thermo switch?
GARY BUTRIM
Engine Cooling problem
1991 Honda CRX 4 cyl Two Wheel Drive Manual
I want to test the thermo switch on my 91 crx and it is not where my repair guide says it should be. It"s supposed to be on the bottom of the radiator between the lower tube and the drain vallve. It is not. the guide also thinks I should only have one fan, but there are two fans. Where else would the thermo switch be? Note: Everything on this car is original equipment.
Mar 1, 2010 at 3:48 AM
KHLOW2008
  • 41,812 POSTS
Hi Gary,
Check the thermostat housing.
Mar 9, 2010 at 5:10 AM
