1991 Honda CRX speedometer cable replacement
120,000 MILES • 4 CYL • 2WD • MANUAL
TDM3
Finally got my CRX running after running the checks you suggested and replaced fuel injectors. Thank YOU-BUT the speedometer does not work. Don't know if it's the cable OR the gear. PLEASE TELL ME HOW do I get the cable out behind the dash?? and how can I tell if it is the speedo cable OR in the part that goes into my 5 speed manual transmission? (Is there any trick to replacing the gear if that is what is wrong)
Apr 20, 2009 at 12:27 AM
F4I_GUY
  • 3,302 POSTS
https://images.2carpros.com/forum/automotive_pictures/276698_crx_speedo_1.jpg
May 3, 2009 at 3:26 AM
