1991 Honda CRX oil leak
1991 HONDA CRX
133,538 MILES • 4 CYL • FWD • MANUAL
D2REAL
i ahve a 1991 honda crx si i recently changed the head gasket it runs great but a couple of days ago it started leaking oil profusely like puddles under the car i cant see where it is coming from from above so i raised the vehicle and took a quick look under and i found thats it is coming from somewhere around the oil filter but not the filter or what it is connected to then i found a hose not connected to something that is above the oil filter i think it might be the oil pump not sure i put it back in but there was still oil shooting out i did'tn get the hose to go all the way back in but i noticed that i do'nt think the oil is coming from ther but its still coming can anyone tell me what this might be?
Jan 16, 2010 at 5:43 AM
MERLIN2021
  • 17,250 POSTS
Sounds like if it's the single wire connector your oil sending unit is leaking, it's right by the filter with a single wire connector plugged into it.
Jan 16, 2010 at 5:55 AM
